メインコンテンツにスキップ
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139回答 すべてを表示
Why is the dryer making a horrible noise
I have a frigidaire combo washer dryer, that is a few years old but hasn't been used a lot. The dryer developed a really bad sound metal on metal type scraping. When I looked inside the dryer I noticed there were two screws (out of 3) that had worked their way out of the center back (inside the dryer). Not sure if those screws were the cause of the noise or the result of it. I haven't tried doing towards fixing it for fear of making it worse.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@theresatay what model is your combo and try to post some images of whast you see with your question. For that use this guide iFixitでの質問に画像を追加する方法 It will allow us to see what you see and we wont have to guess.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Theresa, The 2 of the 3 screws that you have found may be the screws that hold the drum centered in the machine on the drums hub shaft. If you or a friend can reinsert and tighten the screws, do it and try machine.
If you put the screw/bolt in the hole and it just spins, this probably means that this fastener wash installed as a nut, lock washer and bolt to drum hub. In this case the machine will have to be disassembled and you may want to have a technician have a look and estimate repair. Good luck.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Is there directions on doing it yourself?
さんによる
コメントを追加
回答を追加する
Theresa Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 30
今までの合計 2,106
