Laptop goes to a black screen after Windows upgrade
I upgraded my Windows and now when I turn on my laptop it reboots to a black screen. Do I need to uninstall or reinstall Windows to get rid of the black screen?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Danielle, Here is another couple links that may help you trouble shoot/get rid of black screen after windows upgrade. Check the attached link,instruction and guides. Some of the forums say black screen may be because of graphic card issue. Good luck
このアンサーは役に立ちましたか?
Did you upgrade from Windows 7 to Windows 8 or another Windows version? If you upgraded from Windows 7 to Windows 8, you may need to update your system BIOS.
If the black screen is showing up before you've upgraded to Windows 8, you will be able to upgrade your laptop to the latest version of BIOS by downloading the update. If the black screen is showing up after you've upgraded to Windows 8, there will be two options for getting the latest system BIOS. You can refer to this guide for the different fixes: http://www.dell.com/support/article/us/e...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 1,291
