メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Laggy Touch Screen / Unresponsive
i recently bough a second handed iPhone 5s and the owner told me the touch is laggy and the LCD have to be replaced , i replaced the LCD with no Hope the touch is still laggy , i sent the device to a tech. Guy and he checked the phone and replaced the touch ic also with no hope the LCD still laggy.
-i used to Lock and Unlock the phone to be able to use the phone for a minutes then it starts to be laggy again,
-Also reinstalled iOS , nothing changed
i Need an answer for this situation please.
Update (10/28/2017)
FIX : Okay i Have fixed the problem and it was the LCD ! i bought a non-original LCD so it caused that to happen so you need to but an original one that's all.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Laggy as in it wont register some touches?
What happens if you try to use the phone on the table vs while holding it in terms of touch screen performance?
No ghost touch right where it clicks on things itself?
A bit weird because I've never heard of an issue like this before.
Have you read the blog about slow touch screen troubleshooting? may prove to be a bit useful in your case:
http://blog.brokenlcds.com/iphone-5-touc...
さんによる
yes , i have read this article and checked everything the cables , connectors , everything is okay , The phone works perfect while in a cool place i don't know how
さんによる
コメントを追加
1 件の回答
最も参考になった回答
My guess is the lag is a symptom of a different problem. When he locked and unlocked, it fixed the issue for a minute. That would point me towards an app that is hanging in memory.
OP: Try going through and closing out apps and see if it becomes more responsive after a certain app closes. Also, try setting it up as a phone in iTunes. I'm 80% sure this is a software issue, and I would attack that first.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
it's not like lag that it responds after a while , it's like ghost touching , when i type with the keyboard it presses some letters itself and it hold the letters sometimes , actually there's no applications at all i"ve a clean iOS as i mentioned i reinstalled the iOS
さんによる
Have just the same problem on my 5S, tryed even to change display, tryed to restore my iphone firmware with itunes but, still have same problem
さんによる
Okay Danylo i Have fixed the problem and it was the LCD ! i bought a non-original LCD so it caused that to happen so you need to but an original one that's all.
さんによる
コメントを追加
回答を追加する
Omar Farghally さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 4,184
