Rear main seal leak
I have a mazda protege 2000 I have a rear main seal leak. Where can I get a good guide to Do it myself.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Kevin, 2000 Mazda protege rear main seal leak. I f you can, I suggest you check out your local library for a repair manual on your particular model or pop into any auto parts supplier and check what manuals they have to offer. I will post a link that may help let you see what your up against when changing the rear main on protege. Check the attached link,instruction and guide, Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,338
