メインコンテンツにスキップ
Repair steps when monitor was given 12V AC power instead of DC
I have Acer monitor which was working perfectly. Then my cousin got confused with the wire and powered the monitor with cable which has 12 V AC as a supply. That power cable is used for woofers. Since the pin look alike he inserted it. Now even If i insert the preferred power cable it's not turning on. Please help me with this. What might be affected ? If it is possible to repair it by myself please let me know :)
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
ajay shenoy there is no way to make any kind of assumption. You will have to disassemble the monitor and take a look at the main board for any burned component.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
ajay shenoy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 115
