How do I install a new hard drive?
The casing appears smaller than the hard drive and case.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here's how to install a 3.5" internal hard drive. Note that it takes a IDE/ATA drive, not an SATA drive. If installing more than one drive, the jumpers need to be set up as Master on one drive and Slave on the other to avoid a ID conflict.
このアンサーは役に立ちましたか?
Adding the link +
you bought the wrong size HD (possibly one for a laptop not a desktop) Height (mm) 26.1 Width (mm) 101.8 Length (mm) 147.0
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,572
