メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
592回答 すべてを表示
MacBook only powers on with adaptor, doesn't detect new or old battery
So I've been fixing a macbook I got cheap on gumtree that was being sold as faulty. I needed to replace the HDD, fan,LCD and the keyboard and it turns on and everthing works fine except for the battery.
So here's what I've learned from troubleshooting so far
  • Only turns on and stays on only when plugged in
  • Doesn't detect original battery or new battery
  • Tried resetting PRAM, SMC
Any information would be helpful
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi
I had exactly the same problem recently with a Mid 2012 13" Macbook Pro and tried all the steps you mentioned.
Turned out that I had a broken battery sensor (flat connector on the bottom right hand side of the logic board which is connected to the button on the right hand side that shows battery power level)
After disconnecting this connector and doing (yet another) PRAM and SMC reset, the Macbook started working. Will be ordering another battery indicator cable but for now leaving it unplugged. Charging light went orange and it detected and charged the battery right up to 100% and has been sitting running on battery power for hours now with the battery indicator cable disconnected!
Also another thing to make sure is that you have the latest SMC Update installed , as SMC version 1.5 did resolve battery issues. (And SMC v1.8 on the 2012 model)
https://support.apple.com/kb/DL1474?loca...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thanks Alex
It seems that it was the battery indicator was faulty, after unplugging and resetting the PRAM and SMC the power indicator on the charger changed to Orange, and the battery is now being detected by the system.
I've ordered a new charge indicator.
Thanks heaps again!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
You're very welcome! :) Glad to hear you got it fixed
さんによる
コメントを追加
回答を追加する
Carl J さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 74
