メインコンテンツにスキップ
The home base for Android smartwatches.
How do I change the time on an Android smartwatch?
My wife's K88H Smartwatch seems to have all its apps working but shows an incorrect time 4hrs + behind current time. I cannot seem o pair it properly with my mobile on Bluetooth. How can I change the time on it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
11 件のコメント
z66 smart watch the time of watch not set properly please help me
さんによる
Hi. My Kingware 88 time reset to London time -2 when disconnected from phone. When connected again time sync to SA time. How can the watch be set to store SA time when not connected to phone. Thanks
さんによる
Hi can anyone help me change the time on my fb4e ???
さんによる
How to change ky11 smart watch timing?
さんによる
I need hlp attached hw12
さんによる
6件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Hi,
The watch needs to be connected (paired) to a mobile phone so that it can 'sync' the time with the phone.
What type of phone are you trying to pair the watch with?
If it is an Android based phone the OS of the phone needs to be Ver.4.4 or higher. It will not function correctly with Android versions lower than 4.4.
If it is with an iPhone then the OS version of the phone needs to iOS7.0 or higher.
Here is a link to the User Guide which explains how to connect to a mobile phone and how to sync the time.
https://fccid.io/pdf.php?id=2991005
このアンサーは役に立ちましたか?
スコア 8
11 件のコメント:
Thank you Jayeff. Actually, earlier in the evening one of my phones, that has no SIM card bit that I kept to use as a music and video player and for Wi-Fi use turned out to have the right Android and BT levels to sync perfectly with the two Chinese watches that were giving the wrong time.
さんによる
z66 smart watch not set the correct time
さんによる
please help me
さんによる
I need help with a fb4e watch
さんによる
I need help changing the time on a microware X2 smartwatch...no instructions in the manual..
さんによる
6件以上のコメントを表示
コメントを追加
I had buy new watch which is said to be LD5 Smart Watch … And It is replica of apple design and it has option to change time in setting. So all the apple replica watch you can change watch time in setting after changing sysc time from AUTO to MANUAL.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Yesterday i spent about three hours trying to fix this problem. My watch 7 android is connected and it receives calls but a totally different time and date from my mobile.till i downloaded the app of the watch itself ,made an account , removed the watch from recognition of bluetooth of my phone while phone bluetooth is still on. The phone recognized watch thru QR code and i could control my watch thru phone, i even could download and design my own timefaces :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
garnacha さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 74
今までの合計 63,491
