Can you use the same screen assembly for iPhone 5s and SE?
Can you use the same screen assembly with home button and all those things for iPhone 5s and SE?
Can you like switch screens between these two devices???
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi, there are actually some parts they can share in common, and some not, you can check this article to found out, which tells which parts are exchangeble between 5S and SE,http://www.etradesupply.com/blog/iphone-...
このアンサーは役に立ちましたか?
Yes, you can. The two models share completely identical screen assemblies, right down to the components attached to the back of them
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 151
