メインコンテンツにスキップ
初代モデルのiPhoneです。モデル番号はA1203で容量は4, 8,もしくは16 GBから選べます。アルミニウム製の背面ケースです。開口にはかなりのこじ開けるための力が必要です。そして半田付けも若干必要です。
224回答 すべてを表示
締切られた回答
No sound from my external speaker?
i got a used iPhone 1st generation from my uncle several months ago, and it's worked fine up until now. i am able to hear certain things out of my external speaker, but everything else does not make any sound. i don't have my ringer on vibrate, so don't even try saying that's the problem. i cannot hear my ringtone, music (with no headphones plugged in), or even that little clicky sound it makes when you unlock it. when i call someone or someone calls me, i cannot hear them and they cannot hear me. there is only sound coming out of the external speakers (the ones on the bottom of the phone) when i'm setting a different ringtone or when an alarm/timer goes off. i would like to be able to use my phone; can someone please help? thanks(:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
check headphone jack for dust and lint as this may be shorting your sensor and making phone think it has headphones in-hence the lack of external sound.
otherwise you may need to look at the connectors for the display which contain the earpiece. to repair these i think you will need to replace the entire front display screens as it is sold all in one.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,819
