メインコンテンツにスキップ
How to fix damaged lower RAM slot?
My Macbook suddenly started making 3 beep sounds. After I identified it, my lower RAM slot got damaged. Each time i put memory into it, my macbook started beeping. Anybody know how to fix RAM Slot ? I don't wanna spend a lot money to replace the logic board.
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
So I assume if you leave the second ram stick out the computer boots? Try the ram stick from slot 1 in slot 2 and leave slot 1 empty. Does it still beep? If not then the stick from slot 2 is bad
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I've bought 2 new ram stick and put them into slot 1 and 2, however it still keep beeping. Then I removed the ram stick from slot two and my macbook back to normal. I think my lower ram slot is damaged. I have cleaned the slot as some people advised but it still doesn't work.
さんによる
How many Ram Slots are available?
さんによる
2 slots brian
さんによる
コメントを追加
Try using one stick at a time in slot one if the MAC doesn't work with one then make that one as bad. If it works with both then your second ram slot might be bad. If that is the case then the only way of repairing it would be replacing the Ram Slot but being as that is probably a 2M level soldering job it would cost too much to repair it.
You could instead just only use the one slot but put the max ram that, that computer recognizes in that one ram slot. That would probably the cheapest fix. But that would be only half the max RAM that the computer could see if both slot were working.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
westry さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 689
