メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
Backlight on LCD not working
I saw several other people in this situation but no one actually answered the question I have.
Like many I got water damage... my question is if I replace the display assembly, will the backlight be replaced as well?
I have a black iPhone 3GS 8GB A1303.
You can see the display fine in sunlight but if I go into a room or low-light environment I can't see the display at all.
The display is working fine, just the backlight is out.
Any thoughts?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
There are 3 places where damage may stop backlight - LCD, connector1 prongs on mainboard or the backlight coil itself which is on mainboard. Replacing LCD doesn't always cure the problem... There are a few good links on here about how to repair your coil ( James bond I think) . I would try cleaning the phone thoroughly with isopropyl alcohol first- you may have residue spoiling connections
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The downside to that is I am currently stationed in Korea, so getting isopropyl alcohol isn't something feesible right now.
さんによる
anything high content alcohol is all you need. 90% alcohol leaves 10% water, so the higher the % the better. you could just open the phone and try a soft brush to get rid of debris. many people refer to it as "rubbing alcohol" try that at the pharmacy/chemist...
さんによる
コメントを追加
yes, it will be replaced, but it would be sad to pay that much if you could replace a couple LEDs or similar. If you do replace the displace assembly I would be more than happy to acquire your old one for the touch screen component if nothing else.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chris Ballentine さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 9,749
