Why can't I download pictures from the camera to my computer.
The camera was dropped on a recent vacation and although I can view pictures on the camera, I can't download to my computer, as I had previously been able to.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
The USB port in the camera may have broken off the board because of the fall, (or perhaps some other component relating to the USB function).
Have you tried removing the SD Card and inserting it into a card reader connected to your PC and downloading (copying) your photos directly that way.
If you try opening the camera to find out what the problem is you could cause more problems. If this is the only problem with the camera and you can download (copy) your pictures using the method above, then leave it as is.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 223
