メインコンテンツにスキップ
T800 Battery decreasing while turned off and on charge?
Hi
I have a Samsung T800 tablet and which is having some serious trouble charging. It originally had a damaged charging port which was replaced and since then whenever its plugged in to charge the battery keeps draining even while switched off. This also happens with a new battery.
Any ideas?
Thanks in advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
@hortman did it ever work properly after you repalced the charging port? Have you verified that the replacement is properly installed?
さんによる
It did work here for me when i changed it. port does seem to work properly, it shows the battery symbol when plugged in and has the little bubbles. Should I try another?
さんによる
So from what you are saying that it is indicating that it is charging but it is not? I would double check the connector and the connection.
さんによる
コメントを追加
1 件の回答
ベストアンサー
@hortman if your connector and the connections are properly installed, follow the troubleshooting suggested by Samsung.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks oldturkey03 thats exactly what I need, sorry its taken so long to reply, been busy with other repairs
さんによる
コメントを追加
回答を追加する
Hortman さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 95
