メインコンテンツにスキップ
GMCが製造した車、トラック、SUVの修理ガイドとサポート。
290回答 すべてを表示
How replace a cabin air filter
I have a 2012 GMC Sierra 1500 I am trying to replace the cabin air filter , looked behind the glove compartment , under the dashboard nothing.
I have been to OReilly's and LubNgo , they were not able to help me. I check on the Internet , I have been to different websites nothing. I went to mygmc.com nothing, I cant believe that one
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
ベストアンサー
@rolivas your truck does not have a cabin air filter. GM stopped using them some time ago. They used to be under the dash but have been discontinued in the mid 2000's.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thank you it's hard to believe cuz there's a funky smell sometime all the time , and when I went to OReilly Auto parts store they have a replacement part. GO FIGURE. Thanks again
さんによる
I have a 2013 gmc. I had the same problem, not where it’s supposed to be. So I called my dealership and it turns out I do have a cabin filter. It is under the dash. But on mine you have to drop the lower half of a black plastic casing. So for $59.00, I just let the dealership do it. That was labor and filter.
さんによる
My 2012 GMC does not have an air filter in the cabin. There is a blank under the dash but it is not cut out. I did find on YouTube if you want to add one there is a kit to do so and it comes with a filter cover and screw. To install it you will need to cut out the blank install the filter and cover and screw it in place.
さんによる
@mactac101 John Wood, I too have a 2012 GMC. Where did you find the kit please?
さんによる
コメントを追加
回答を追加する
rjr3598 さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 63
過去 30 日: 224
今までの合計 18,813
