メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
Strange Power Problem and Boot
Hi All,
I have here one iPhone 5s that dont charge and dont boot even with an charged battery.
Laptop connection dont detect the iPhone or even charge it.
I replaced the battery for another and he starts boot but just shows the apple logo and nothing happens.
I changed the MotherBoard to another housing and same problem, no charge and no boot (Just Apple logo)
There is someone with same problem?
Best Regards
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Any more ideas?
Its strange because usually we have power problems but not boot problems.
If i dont have boot problems i'm for sure that is the U2, but is strange the problems with the boot and the Computer dont detect the iphone.
Any more suggestios or same situation?
さんによる
コメントを追加
2件の回答
ベストアンサー
Sounds like the Power IC on the board itself. Also known as U2 or Tristar.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I thought in that, but i dont usually get the 3 problems when is the U2.
- No Charge
- When Power On with an charged battery dont fully boot, stays in Apple Logo and sometime restart.
- Dont Connect with computer
What the customer said is that, at night he put the iphone to charge and on the morning the iphone didnt power up.
When i received it the first thing that i did it was try to turn on with an new and fully baterry and he power up but stays on boot (Apple Logo).
Do you have ever have one case in same situation?
さんによる
Yes this sounds like a classic Power IC U2
さんによる
コメントを追加
Analyses
Symptoms of U2 charging logic ic failure:
Fake charging - NO - No charge at All
No charger detect - YES
Inability to charge a stone dead battery, but can charge a partially charged battery - NO, No Charge at All
Very rapid battery drain - Maybe, Cant test
Heat at U2 ic chip - NO, Dont feel no Heat
Auto power on at battery reconnect - No, No Auto Power
Inability to restore due to dropped usb connection - Yes, no USB Connection
Some subset of 'blue screen' problems in iPhone 5s and possibly mini retina - Yes, Sometimes Rebot after an bluescreen
So what we have:
- Some subset of 'blue screen' problems in iPhone 5s and possibly mini retina - Yes, Sometimes Rebot after an bluescreen;
- Inability to restore due to dropped usb connection - Yes, no USB Connection
- No charger detect - YES
So, i have three Symptoms of U2 charging logic ic failure, maybe really the U2 Chip, i will try to change it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Paulo Silva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 103
