メインコンテンツにスキップ
The BLU Vivo 5 is an Android smartphone produced by BLU, an American consumer electronics company. The 5 was produced through a partnership between BLU and Vivo Communication Technology Co. Ltd., a Chinese technology company. The BLU Vivo 5 was released in February 2016.
Where did my call log and messages go?
So I have all of my contacts but all of my messages and call logs disappeared. When I go to my settings it says I have all of my messages but when I open the app or hangouts I have zero threads. It will also notify me when I have a new text message but I cannot see said text anywhere. I tried resetting my messaging settings and it didn't work. I'm incredibly confused. Help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
3 件のコメント
I have a vivo y21l phone but after 4 months of buying it does not show any recent calls and missed calls rather it shows old calls what to do next..
さんによる
Have you solved this problem? It happened to me. But i still cant fix it
さんによる
Hello
I have vivo v5 and i was block a number and the block number and messages remove from my message inbox.
My all messages go in to i manager block messages.
I want to move that all messages from i manager block message inbox to my vivo v5 default message inbox after unblock that number.
How to fix this issue please help me to fix this issue.
Thanks
さんによる
コメントを追加
11件の回答
最も参考になった回答
It may be because you accidentally turn on the "guest mode".
My sister also has a vivo 5 and experience pretty much the same problem. She can't see any call log, and all the picture in the album are gone.
In the file explorer I was able to find the pic under DCIM folder, but don't have the access to view it. The phone pop me a message saying I was not allow to see them because I was in the guest mode.
So I go to setting->security-> and turn off "guest mode". Everything come back, hope it also work for you.
このアンサーは役に立ちましたか?
スコア 25
22 件のコメント:
Oh. Fantastic. Thank you very much for your suggestion. I had the same problem and I very much worried. After seeing your suggestion and tried off from guest mode. I the problem solved. Thank you very much.
さんによる
Thanks you I turned off my guest mode like you suggested and my call and messages are back,, thank you sooooo much
さんによる
I can't find the guest mode on my Vivo 5R.
Can someone help me ASAP. Justice
さんによる
I can't find guest mode either, any help?
さんによる
Thanks.... It works
さんによる
17件以上のコメントを表示
コメントを追加
Justice Sackey I emailed Blu support and they told me to go to settings, security, unknown apps installed, open it download guest mode doc, then you can close that setting back to unopen. It worked I got everything back.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
What is the process of delete call log in vivo v5 phone
さんによる
@aliceca , I have same problem with 5R, I cannot find "unknown apps installed". Is it hidden under other section? Thanks.
さんによる
After the phone being updated to the latest version *v24_generic_6.0_07-6-2017, the "Guest-Mode" check box showed up on "Settings" - "Security". Finally, I got the call logs back.
さんによる
I'm experiencing the same problem. I am unable to find any of the options in security, and not sure how to get the phone to update as mentioned above. Would be grateful for any suggestions... cheers
さんによる
I have an XL2 with the same problem, I followed the instructions and got everthing back. Thanks @dzpcool!
さんによる
コメントを追加
Thanks for this info...I now have my messages, pictures and call log back.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It worked for me .Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
hey everyone, I have vivo xl and after a certain date I have lost some messages. I never lost my call log or contacts... HELP!
さんによる
コメントを追加
This is probably because your guest mode is turned on. Go to settings>security>guest mode and turn it off. Hope it works for you.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It doesn't have that option when I click security
さんによる
コメントを追加
Hello
Thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have Lenovo k6 note with venom os
I can't see my recent calls and messages..
What to do ??
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same here. I can't see my call log or pictures.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Your a deleted it or your phone glitches out. Don’t be too hard on your self, computers are complicated.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I can not see the Miss calls numbers on my
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thank you,
Your answer to the problem worked like a charm. Resolved within 30 seconds vs. my having spent a lot of useless time before reading your answer. Thanks again. Mike M 3/25/2020
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Angie kriess さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 71
今までの合計 35,249
