Rear Camera causes heating.
Received iPhone Plus 64Gb with both camera's not working. Installed working 64Gb logic board. It would not power up and the area by Camera IC's started heating up to the point it was barely able to touch. Disconnected rear camera and the board booted up fine.
Replaced rear camera with brand new one. the board would not power on again and it started heating up as well. disconnected camera booted fine and works well??
Is there a short in this case that is going through the camera that is burning the board up??
There is a coupling grounding connecting flex cable from the rear camera cover to the logic board. I was sure that I had it connected but if it was not would it cause the heating issue.
Mathew Naut さんによる
