メインコンテンツにスキップ
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
20回答 すべてを表示
I need to replace the glass
I have a LG v10 and I need to replace the glass
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
The glass screen on this phone is repairable, but difficult. You can get it professionally repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
さんによる
コメントを追加
2件の回答
ベストアンサー
Here is a link that should help. Tap or click on the blue link. Good luck.
https://m.youtube.com/watch?v=H5VDlpRFBK...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The glass is difficult to repair on this phone, but repairable. You can get it repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
さんによる
コメントを追加
最も参考になった回答
They sell just the glass online, but I would highly suggest you avoid that. The entire assembly is glued together and there are some very delicate components between the different layers. I was unable to replace just the glass and ended up destroying the whole LCD screen in the process. Your best bet is to buy the whole display digitizer touch screen assembly. They currently run about $150, but most of the videos online about replacing them include the entire assembly, including the one above.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I dropped my phone and the screen had spider web cracks. Then I just took off the outter screen. It was a pain in the butt but it still works as it did before. Im guessing the outter screen isnt the digitizer?
さんによる
What did you do to remove the outer screen? Is your phone the V10?
さんによる
I wish i knew that before i attempted it] not just the v10 but also on the LG stylo 2 plus.dead
さんによる
コメントを追加
回答を追加する
Luis Milla さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 7
今までの合計 6,374
