メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Cheesecake stuck in headphone jack
Alright so... me being the stupid teenager i am, I dropped my iphone in my cheesecake. It's stuck in the headphone jack and my volume doesn't work, it's also in the microphone and speaker. I don't have enough money to replace the phone or the components, please give me a cheap hack to fix my phone! My mom will kill me if she finds out what happened :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Best option at this stage is to turn the phone off and use the sim pin that came with it (or something equally small, like an earring) and clean out as much as possible. Make sure the headphone port and the lightning port are as clean as possible. If you have fine tweezers, a small amount of cotton wool on the end of them could also help. If the above is unsuccessful you will need to have the headphone jack ribbon cable replaced.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
On a dry day, place it next to a bed of sugar ants. They will fairly quickly have it cleaned out.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Can you please help me with my Macbook Pro "mayer" ? Thanks (link to my question: Reseated RAM, blank screen, beeping every 5 secs. tried everything ...)
さんによる
コメントを追加
Try using a vacuum cleaner to suck out the bits of cheesecake from the headphone jack. Also use it to attempt to clean the speaker and mic. Use tweezers and a pin carefully to do the rest.
Otherwise, my only other thoughts are to clean it of cheesecake as much as possible and dare I say it, return it under warranty.
Regards,
Barney
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Fall Out Narwhal さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 175
