メインコンテンツにスキップ
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
20回答 すべてを表示
unable to turn it on
i have a problem with my laptop "dell inspiron 3521" when i press on power button nothing is happening there is no response , and when i connect the adapter , the led of the adapter starts to blink and stops when i disconnect the adapter from the laptop
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Waleed Hamdy have you checked teh output of your AC adapter? Is it the right voltage for your Dell? what else have you tried? How long has this been going on?
さんによる
since yesterday my laptop is not working it happened suddenly , i think the adapter is working well as i have tried another adapter and it had made the same blinking on connecting it to the laptop
さんによる
Try to remove the battery, the AC adapter and tyour RAM memory. Then push and hold down the power button. Do so for a few minutes. Then replace the battery and one memory module as well as the AC adpater and see if it shows anything.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Waleed, As oldturkey suggest try a reset. From post in another forum I read, possible it could be a faulty/worn out battery. Check link below. Hope it helps, Good luck.
http://www.geekstogo.com/forum/topic/340...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Waleed Hamdy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 168
