メインコンテンツにスキップ
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52回答 すべてを表示
Canon Rebel T3i drop damage on LCD
I'm assuming I can diagnose and repair this camera without a lens attached.
Canon EOS Rebel T3i was dropped. When I insert an SD for the first time, the camera creates the DCIM\EOSMISC directory and creates the M0100.ctg file inside it.
The screen generates a backlight, but no image. Pressing Menu (and perhaps the Info) button seems to toggle the backlighting (and/or image).
The screen actually looks intact - I fail to see cracks.
I'm thinking about three parts that could be bad:
1. Screen
2. LCD Display Screen Board PCB DH2826
3. Blue cable connecting the body to the Screen Board PCB
I know the Screen and Screen Board are available for purchase separately. I hope the blue cable is still intact. What else can I do to pinpoint which part(s) need replacing?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The easiest fix would obviously be to check the ribbon cable. After all, the cable might have simply become dislodged. My advice would be to start with the easiest fix and work your way up to the hardest.
Did you try taking pictures with the camera after you dropped it? If the camera can still properly take and save the photos, you would at least know that your shutter box, sensor, and logic board aren't damaged.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I got around to working on the camera again. I reseated both cables attached to the LCD. There is no change in behavior. Might pull the trigger on a replacement LCD but still wondering if LCD Display Screen Board PCB DH2826 is defective.
さんによる
コメントを追加
回答を追加する
lkvee さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 248
