Why is my laptop not powering
Water got poured on my laptop keyboard which makes its not powering but when I put a charger in its charging port it's shows light at d charing singal only,so what can I do in a situation like dat?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
jboy, Use the links below to hopefully get your laptop up and running again. Check the attached links,instruction and guides, Good luck
http://www.laptoprepair101.com/fix-lapto...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 127
