メインコンテンツにスキップ
MacBookファミリーは2006年5月に登場しました。Appleの人気ラップトップであったiBookから引き継がれました。
3787回答 すべてを表示
締切られた回答
new display works for 1 second and then goes off
Replaced cracked display screen with new one.
When booting up I have a black screen.
Using flash light I can see graphics or text only for a short time.
Installed new inverter board.
Now when I boot up screen is still black but when I touch spacebar for example screen comes on perfectly for 1 second and then shuts off. I pressed the number lock button and Caps lock button because they light up . Noticed lights shut soon after and noticed sleep light goes on.
Can you identify the problem? Please help. Its annoying when you have only a perfect screen for 1 second.
Thanks, Bob
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Good news
is changing the sleep settings (energy saver) may solve this by target booting your Mac and copying over the .plist files from another machine running the same OS set to disable password, disable "put the hard disks to when possible", disable hibernation (set battery and screen to "Never"). .
BAD NEWS is if that doesn't you could have a hardware problem in one or all of the logic board, magsafe connector, or the battery connector sleep switch.
Whichever answer is helpful please remember to mark it accepted.
Good Luck,
N
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 834
