メインコンテンツにスキップ
Why logic board chimes when pin is touched with probe?
Hello Guys,
Maybe one of you can help with this unusually weird problem I have with my 820-2330 logic board. The board powers on, but won't chime or boot until I touch a couple of specific pins on chip U8900. This is what happens exactly; when the board is powered on and I touch pins VO or OCSET on U8900 the board then chimes and boots normally. It is driving me crazy trying to figure this one out. At first I replaced U8900, then I replaced both FETS, then I replaced the Critical caps after the inductor all to no avail. Any help would be appreciated.
Thanks,
Roger
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Look for an open trace or bad component attached to one or both of the pins you mentioned. If an input pin is not connected, touching it with a logic or scope probe connects it to ground through the probe circuit, thereby giving it a logic low (“0”)signal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Roger さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 65
