Open the HP 15ac137cl Case
How do I remove the back cover of the HP 15ac13cl so that I can replace the hard drive?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I thought I had marked this issues as solved. Thank you so much to everyone that helped!! There were two hidden screws underneath the rubber pads near the monitor's hinge. Once they were removed, it came right open.
このアンサーは役に立ちましたか?
HP has a link to their repair manual PDF here:
http://h10032.www1.hp.com/ctg/Manual/c04...
Looks like there's a Service Door that may help.
このアンサーは役に立ちましたか?
Thank you! I'll read a little deeper since this particular model doesn't have any service doors or access panels to anything. There might be a clue in there somewhere tho!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 213
