Seagate Hard Drive Model ST380011A
Hey THere !!!
i messed up with mah described above ... actullay i pushed that IDE cable a bit harder ... :| ... n broke one pin mmm actually two pins ... one on the uper row n other on the lower row ... i dont know what to do know .. mah hard drive is not detected ... i used some metal pins n tried to put them in place of the broken pins .. only 1 out of 10+ attempts ... the hard drive ran .. n detected ... n showed all the data .. but then ... the pins displaced n .. again it vanished from the screen ... atleast here i know that only those broken pins are ^!^^@@^ mah hard ... so is there any ... way i can fix them ? like :D ... mah dear hard again gets alive ? :( plz help ppppp .... thanx in advance :) ...
P E A C E !!!!
この質問は役に立ちましたか?
2 件のコメント
with mah hard drive ****
Gambler881 さんによる
http://i867.photobucket.com/albums/ab235...
here is the link .. for further assistance .. you can see the red circles ... showing the broken pin spaces ... so .. plz help :) .. thanx
Gambler881 さんによる
