メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1169回答 すべてを表示
Dropped iPhone 3G not responding
After being dropped, my iPhone fails to respond. The drop was bad enough that the mute button broke. At first, I could get the Apple logo after pressing on the home & power button (but it would not reboot). Now, even that doesn't work!
I opened it up and check on all the usual contacts and all appear to be OK.
Anyone have any ideas? Apple won't even look at such an old model - their solution is, of course, buy a new one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If you plug it into a charger, do you get a battery icon or Apple logo on the screen? If you plug it into a computer, does the computer see it?
A drop that had enough force to knock out the mute button on an iPhone 3 had a lot of force. Also, your solder is going to be very brittle by now and easily damage.
There are a whole list of things that it could be, but we need some more information to narrow it down. Please answer the questions above and we'll try to point you in the right direction.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks fot this answer.
I have already posted this comment but am not sure that it has been received ( I can't see it!)
After the fall, I tried to activate the phone using the computer and keeping the home & power buttons depressed. The first couple of times, the Apple logo appeared but the phone did not reboot. Trying again the logi no longer appeared and there was no response apart from the occasional flimmering of the screen. The computer does not recognise it.
Examination of the 6 numbered contacts and the ribbon conections shows no obvious problems.
さんによる
コメントを追加
回答を追加する
Christopher Gray さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 54
