メインコンテンツにスキップ
Released in the fall of 2004, the 700m features a 12.1" widescreen display and a 1.6 GHz, 1.8 GHz, or 2.0 GHz Pentium M processor.
4回答 すべてを表示
Can I upgrade this old computer
I have a Dell Inspiron 700 m with Windows XP which is running well. However, as Windows XP is no longer supported I am afraid to connect it to the internet. Is there anyway to upgrade this computer so I can run a more current version of Windows which would allow me to add anti virus software to safely connect to the intranet? Thank you in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Thank you for the advice . I will check out the sites you recommended
さんによる
You can improve the 700m by using a dual band network card, The 2915abg is a
dual band NIC with a PCI plug and works good. it was used on an earlier model
and I dont why this NIC was never mentioned. I am intending to ask MKafee if
they have a package for windows xp to guard against problems while on the web.
さんによる
コメントを追加
3件の回答
ベストアンサー
@terrymcd biggest issue here will be the display driver. dell does not provide any approved ones for your model. There are work arounds so you could in thoery update to Win 7 at least. However you can upgrade your memory to max it out and also optimize your hard drive. Just because there is no longer support for Win XP does not mean you have to stop using it. You can get lots of anti virus for Win XP so you can safely connect online. Places like this and this one are a good start checking things out.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I would put linux on it, viruses won't be a problem, and it will run fast on old hardware.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
you can add linux to your machine (but be aware: modern linux can have issues with your machine (I tried ubuntu, fedora and I got a lot of issues)
I decided to use open suse 12 (which works great)
note also that when installing the celeron chip do not display the PAE bit, so you must append this to the installer: forcepae
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Terry さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 1,338
