メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
iPhone 6 disabled, emergency call one, TOUCH id no go
Took my phone screen cracked, got moisture in it, screen began to glitch and got to the point of really bad distortion, it began to malfunction and make calls out, bring up random applications with out command. Phone became disabled. Took it to Batteries plus and paid 122, guy said the battery was swollen and strip is red verses white, he didn't want to take out the battery until we knew for certain that there was no internal issues.
Touch ID isn't working after the screen replacement. Now that screen is fixed iPhone is asking to be connected to iTunes with iPhone disabled screen, when I swipe it only gives me emergency dial pad, so I cant enter passcode for iTunes to allow sync! How do I fix this?!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
Do you have a computer that has iTunes on it that you have already synced with in the past? If so then you can use that to restore through iTunes without needing to sync it again.
Otherwise follow the instructions here : https://www.theiphonewiki.com/wiki/DFU_M...
This will put your phone into DFU mode which will allow you to restore the device through iTunes without syncing it. Once you have restore the device you should be able to set it back up.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
OP: DO UPDATE FIRST, it might remove the disabled without needing to restore the phone which basically wipes anything. Use restore as last resort.
さんによる
Thank you! I was able to save it and fix the screen. :)
さんによる
コメントを追加
home buttun not working,touch id not working,how to unlock my disabled iphone with emergency
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
please help me how to unlock my phone with emergency number
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
sir,when i connected to lap the usb also not connecting,help me sir
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chandelle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 971
