メインコンテンツにスキップ
本製品は、2010年7月27日にAppleから発売された解像度2650x1440ピクセルの27インチLEDディスプレイです。モデルナンバーはA1316。
78回答 すべてを表示
Fan runs on full power without regulation
Hi Guys,
when i start my monitor, the fan start to running -in my opinion- with the full power.
Okay that would be normal in the beginning BUT it dont stop ...
The fan is so loud and underneath the display there is a lot of air output on the LEFT side.
Actually i tought when i set the brightness to MINIMUM and have only my desktop open on the cinema, it will regulate the Fanspeed to a minimun so you cant hear anything of them ... but it still stays on the fan RPM level...
I dont know what to do ? Maybe is there any temperatursensor broken ??
The Monitor ist connected on an iMac 5k Late 2014.
And yes i have the usb also connected with the iMac.
Please help me :(
Thanks
Manuel
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
From what you have described it sounds like a temperature sensor is either having issues with:
1. Reading the right temperature.
2. Has been knocked out of place or tampered with.
3. Your Monitor is actually heating up to a temperature in which the computer believes it should turn that fan on high.
If you really think that it is an issue with the temperature sensor, and not your computer actually over heating. I recommend the program Macs Fan Control (http://www.crystalidea.com/macs-fan-cont...).
This program will allow you to adjust the RPM of your fans and also view in Celsius or Fahrenheit what temperature the components in your computer are at.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Manuel さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 7
今までの合計 199
