メインコンテンツにスキップ
Samsung Galaxy S6 Edge+ はGalaxy S6 Edgeスマートフォンの大型モデルです。
99回答 すべてを表示
Would a full screen assembly of G928F work on G928A?
I have a repair wanting to be done for a Galaxy s6 Edge+. I try to stick with the guys that I usually buy parts from. The s6 edge+ is G928A, but I am being offered a G928F full screen assembly with small parts. I just want to be sure that my leg isn't being pulled and if those are compatible or not. Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi,
For what it is worth, this supplier shows that the screen and digitizer assembly are compatible.
You could always contact them to verify.
http://www.etradesupply.com/catalogsearc...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
http://www.repairsuniverse.com/samsung-g... Thats the part I was basically asking about. Its the full screen assembly of G925F and not just the LCD and digitizer. eTrade Supply shows one full screen assembly but it shows to work only on G925A. The lcd and digitizer options say G925A and G925F.
さんによる
Hi,
Suggest then that you contact Etradesupply (even if they don't supply) and see what they say. At least that way if they agree with your supplier that's two who say it should work.
さんによる
If it's without the screen frame it will work on all sm-g928 models.
The difference with the modeling of the last letter (SM-G928x) is for different carriers such as T-Mobile, sprint, Verizon and stuff like that.
They also use different firmwares (system software / Android operating system) that are suited best for that model.
It's been like this for Samsung phones for quite a long time. I don't think they have changed that yet or plan to in the future.
Though if the screen comes with the frame it will matter as antenna, wifi, bluetooth and baseband chips on the board will be in different locations which will not let the board sit in properly with the frame.
TL-DR: Do not worry about the last letter if the LCD is without frame. It matters that the model number starting with sm-g928 is the same, excluding the last letter.
さんによる
Thank you! I've been dealing with this dilemma for days with a sm-g928v and all I could afford was the sprint model. Now I feel more confident that itll work once I get it off the frame. Thanks again.
さんによる
コメントを追加
Is g928p n g928f screen same
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Are sm g928p n sm g928f logic board same
さんによる
I have changed screen for sm g928i but it did not turn on
さんによる
コメントを追加
回答を追加する
Carlos Ramirez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,355
