メインコンテンツにスキップ
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
426回答 すべてを表示
How to reset the password
how to reset the login password ????
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 84
36 件のコメント
I reset my tablet now all it does is show the RCA screen and ask for a password. I put in the password and it says it's invalid. Please help
さんによる
We just bought two of these. One works amazing, the other one won’t turn on at all? Is there an option to try before returning it?
さんによる
no good for tablet
さんによる
Mine is new out of the box. Asking for a password. No idea what it wants.
さんによる
I Can’t use the google play app
It says update latest version but it doesn’t let me
さんによる
31件以上のコメントを表示
コメントを追加
16件の回答
ベストアンサー
@tieubao , con, Fluffy thug life , You will have to factory reset your RCA 10 Viking Pro tablet if password is forgotten,(this procedure will remove all data). Power the device down completely, and then hold both the volume up button and the power button until the RCA logo appears on the screen. When the screen changes to the Android bot on his back, press and hold the power button and then press volume up once more. At this point, the Android System Recovery screen appears, with a list of options. Use the volume up and down buttons to navigate the menu and make selections accordingly. To reset the device, scroll to "wipe data/factory reset" and press the power button. Confirm the selection by scrolling down through several "no" entries until the word "yes" is visible. Highlight "yes" and press the power button. This info. supplied by link below which has more info. for you to read. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ebay.com/gds/How-to-Reset-an-...
このアンサーは役に立ちましたか?
スコア 56
40 件のコメント:
I did all of that but it is askin for the Google account previous synced with the tablet. ..I got it from a friend who couldn't remember it so he bought another one
さんによる
thank you so much, worked perfectly
さんによる
Worked great for me
さんによる
ive tried this numerous times with no luck whatsoever!
さんによる
I am a total computer of fraidy-cat work perfect for me!!! Thank you for providing the solution for me ;- ]
さんによる
35件以上のコメントを表示
コメントを追加
well i have the RCA Viking Pro 10" tablet and at no point and time does a robot show up on my screen i can hold the power and volume up button down for 5 mins and all it does is go back and forth from the RCA dogs and the words Viking Pro if i let go of either button it just loads the locked screen as before asking for a password i cant remember. For me all this was and did for my tablet is restart it it did NOT reset anything. And yes it uses the Android 5.0 Lollipop operating system. If anybody is curious as to why the factory reset function was disabled on this device the model number is RCT6303W87 DFK, good luck and happy hunting i'm going to get my 10oz titanium framing hammer and fix this piece of junk.
このアンサーは役に立ちましたか?
スコア 12
9 件のコメント:
Volume button on back of tablet.
さんによる
Yes ! Button on back ,thankx Lynny
さんによる
How do I reset my password on my rca tablet with out losing my picture
さんによる
There's a "reset" button on the back. I randomly tied the reset button and the instructions above and eventually I hit the right combination.
さんによる
I had the same issue, 4 hrs tried their reset method. Mine had some fast load thing that prevented it from going into reboot screen.. so here's what worked.. power on, at rca screen power off.. repeat til it thinks there is a problem loading windows and does self diagnostic. Choose advance settings, factory reset.. done.. you'll know if you have the fastload if your also yelling at an inanimate object "I'm doing it exactly like it said, you p.o.s." for more then 30 minutes..
さんによる
4件以上のコメントを表示
コメントを追加
Hit the reset button on back of tablet, immediately hold the power and volume + button. When you see the RCA logo, let go of the power button but keep holding the volume + button. Hold until safe mode menu appears. (This worked for a tablet pre-equiped with Windows 10) Choose factory reset from here (Note: factory reset removes all files and presets of the device)
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
this is the only one that works for me all the other ones were &&^&^$^ waste of time
さんによる
This also worked for me after other attempts failed ... power + vol up is the key to the reset mystery.
さんによる
コメントを追加
I had the same problem and this helped me: First, don't hold in the power button, just push it. Then push it again and then hold it in. Hitting it that once was to make sure it was locked properly. Then you can hit the restart, reboot, help, etc, but that depends on the phone you have. You can also hold power and volume up button at the same time. If you use volume down for this technique, it will just take a screen shot and you will have to start all over. If you didn't lock it yet, download a screen pin with wallpaper app to replace the PIN with a brand new one. I hope this helped you! Thanks!
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Help me rebuild my rca tablet.
さんによる
コメントを追加
My daughter passed away and left my granddaughter with an RCA Galileo tablet. Of course we don't have password so I factory reset it for her now it wants the google account associated with the tablet. My daughter took that with her too. Can I not reset this tablet for my granddaughter? She's only 11 and wanted her Mommys tablet so very much.
このアンサーは役に立ちましたか?
スコア 0
9 件のコメント:
Hi let me start by saying I'm sorry for your loss. I am no means a tech person. I came to this website because my daughter is 8 yr daughter put a password on her device and I'm sure she doesn't know it. I reset it. Your comment/question touched me. You may want to try and email Google or search deceased loved ones account. Because settings now ask you if in the event of your passing who do you give access to. I hope this helps and you can gain access.
さんによる
Thank you very much. I am still in shock and denial sometimes. She was only 35. ☹️
Honestly, I don't know what email she used because last time we emailed she was in college and used ivytech email which I am sure is no longer valid since she graduated in 2013. We talked/texted daily and never had a reason for email. I know my granddaughters, lol. Yes, already tried it.
I will email google and see if they can help. IF I can find a help email for google. Seems last time I tried to reach out to them, I ended up lost in help pages.
さんによる
Rhonda, if you are still needing help resetting your tablet and bypassing the google protection contact me, I'm a computer scientist and I can successfully bypass google no problem. mechanicalgooroo@gmail.com, my name is Keith aka Grasshopper. have a great day and so sorry for your loss, I'm 40 and just about all my friends are gone to a better place also. Life is too short, enjoy every breath as if it were your last.
さんによる
i bought my brother an RCA viking pro when he went into the nursing home. he passed away last Wednesday. i now have the tablet. did the factory reset 4 times but it still wants the google account associated with the computer. this is so frustrating.
さんによる
@Ellen Laken .. I got u... Breathe... I figured it out.. email mechanicalgooroo@gmail.com
さんによる
4件以上のコメントを表示
コメントを追加
My tablet will neither shut off or turn on . All it dose is eliminates​ slightly around the edges. Help.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
on the back of the tablet there is a little pin hole towards the left side of the tablet.. put a thin firm pin/sewing needle/garbage tie press the button and it will restart the tablet..other wise you have to pull the back off and unplug the battery real quick.. if you need help let me know.
さんによる
i know its a bit dated for the reply bit i hope it helps some one else.
さんによる
コメントを追加
Hi not sure if your problem was resolved yet, but when you factory reset it goes to a second question which is a bunch of no answers and one yes. The yes is to delete all previous user data. I choose this option every time and tablet return shipping to brand new out of the box condition.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Mine Doesn’t even go into a series of yes and no questions after I click the white data
さんによる
コメントを追加
Viking pro factory reset fallowed all instruction now it wsnts google account info i never put it in why is it asking for this i got it new in the nox and what ca.n i do
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Doing the dame to me did you ever get an answer?
さんによる
Did you try entering your Google account ID, and then leave the password blank?
さんによる
If its brand new then its asking for your specific google information in order to link it to the tablet, its not asking for old info.
さんによる
@bh1of7 I have the answers.
さんによる
Ive reset mine and still goes to a screen asking for a previous google account associated with this tablet. I dont have this information. Tried with another google account and keeps going back to previous account associated with this devise.
さんによる
コメントを追加
No Its says I changed my passwors Have to wait 24hrs. Its been over a week Cant get in
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Nick have you been able to fix your tablet? if not, hit me up. mechanicalgooroo@gmail.com. I'm a guru with computers and electronics, and google cant stop me (yet) ;) - Grasshopper
さんによる
Figured it out whuttttt
さんによる
コメントを追加
We're &&^&@@ ¡/!!!!????///!!!!????!!!!!!
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I can bypass any google protection on any device, hit me up. mechanicalgooroo@gmail.com -- Keith aka Grasshopper
さんによる
Can you help me out. I have a rca viking pro and the dam thing still wants my old Google account. I purchased a bunch of old tablets from a lady she don't know the password or gnail.
さんによる
@godofyouall489 hit me up I got ya
さんによる
Can u also bypass numeric account login password
さんによる
コメントを追加
I have a RCA 10 Viking Pro, and what I did and I backed up my stuff onto a MicroSD and then I reset it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I purchased a Viking 10 second hand and can’t get in. I tried the factory reset and nothing will totally clear the device.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Nothing that is but me hehehe.. email me chap
さんによる
I am in the same boat as tbcwerner, I have factory reset, hit the reset button and tried everything else I know and can't get anywhere. Pls help
さんによる
コメントを追加
I bout a rca vicking pro I also can't get passed the Google part wanting old one. Ive tries everything. Any advice please
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Email me we'll talk if u still need help I've created my own answers
さんによる
Please! Would love to know how. Did a factory reset but can not get past the need a password or previous pin!
さんによる
コメントを追加
The only way you can erase the password to reset your Rca Voyager or other models is to open the unit up and change the mother board I had to now it works good
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Incorrect! I figured it out
さんによる
I have my own walkthrough if you are interested
さんによる
Interested! My son’s Viking pro has been laying in his room for a few years because he forgot his google password and sign in... I did the factory reset numerous times but can’t get past this google part.
さんによる
I need help too! I have a refurbished rca tablet and I can’t get past the pin verification!
さんによる
コメントを追加
Ok I opened a messenger Facebook message. It prompted me about a virus happening and it was counting down and $@$*. I factory reset it through the setting. It comes on and it's black screen ,only the icon is of the internet and battery life ., I pressed the little button on the back that says factory reset ,now it's won't come on.and the screen is still black. What do I do.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can't get past enter passward.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have a vicking 10 12in compact computer I bought don't have Google password how do I get into it?
さんによる
コメントを追加
回答を追加する
con さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 120
今までの合計 137,080
