メインコンテンツにスキップ
Microsoft Surfaceのアップグレード版モデルです。Microsoft Surface Pro(1514)のラップトップ/タブレットは開口作業が非常に難しく、デバイスの破壊なしでは修理はできません。
573回答 すべてを表示
SSD replacement on Surface Pro
Hi guys.
Hope someone could give me a bit of advice regarding Surface Pro SSD replacement.
I was given a 1st Gen Surface Pro 256GB tablet with a dead SSD for free. The unit is in excellent condition and boxed, so I was quite keen to repair it. Using the iFixit guide I managed to remove the screen/digitizer without damaging the assembly or the ribbons.
Now my question is this - can I use any make msata SSD to replace the dead one? Are there any makes I should stay away from for reasons such as bios detection issues, booting problems, etc...
Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The term "msata" means mini sata, so there should be no issues with any msata drive as it uses the standard sata interface, that said if I were to make a recommendation I would say get either a Samsung SSD or an intel one, preferably of the MLC or v-nand (also know as : 3D-vertical) flash type as they have the best speed to reliability and pretty good capacity as well
Here is a good one... you can change the capacity,
http://www.newegg.com/Product/Product.as...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Bailey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 544
