メインコンテンツにスキップ
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
74回答 すべてを表示
F150 2014 Iwe4x4 grinding and rubbing sound in 2wd and In 4wd
I have a 2014 stx 4x4 that keeps having grinding and rubbing sounds coming from the front end. Sometimes it comes when just driving in 2wd the other times when shifting into 4wd. I took it to the dealership 3 times so far. The first time they said they replaced all 3 IWE'S. The sound went away for a week. So I took it back the second time they replaced the front axle and the solenoid for the IWE. They had it for a week this time I picked it up friday and its still making the whinning and grinding sound like its partially engaged. The truck was sold to me certified pre-owned and only has 19,000 mi. Has anyone else had these same problems?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
最も参考になった回答
Hey James,
I found a forum post that might help. Check This out. Sounds like if you already replaced the solenoid, you may have to replace the IWE. There's a trick in there about driving 4x4 or pulling vacuum lines to have the truck drivable.
Cheers
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks I'll check it out
さんによる
コメントを追加
I believe there is a technical service bulletin (TSB) for this issue. I had the same issue and the repair included installing a vacuum check valve at the solenoid.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Se dañó la climayera y no ay porque es electrónico
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
James Starrett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 31
今までの合計 9,043
