メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
Power but no sound on tv on my 55 inch
I have a 55 inch led hdmi digital TV and the volume turns down by its self , and remote doesn't work when the TV does this . I tried to use the buttons on the tv, but that did not work . I also tired unplugging and holding the power button on tv . That seemed to work temporarily, but then it happened again . What can I do to fix it ? Please help. Thank you.
The model number is fw50d36f.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
what do you mean by volume turns down by itself, like you can see the dialog box and the volume going down or just no sound?
さんによる
Hi,
Try taking the batteries out of the remote and see if the problem occurs. You may have a sticking Volume down button in your remote.
さんによる
The dialog is up in the left corner and u can see it going down fast . I did think the same thing about the remote but I took out the batteries n turned the TV up with the bottom on the TV a few minutes later it was at 0 .
さんによる
@cookiemonster38 sounds like a bad button board. the problem is going to find a replacement.
さんによる
Thank u all for ur helpful hits I am going to try the button board n see if that fixes the problem
さんによる
コメントを追加
1 件の回答
最も参考になった回答
From the information that you have given, my best guess is that the side panel buttons on your TV are malfunctioning. It sounds like @oldturkey03 had the same idea. If this is the cause of your issue, a temporary solution might be to simply disconnect that panel completely, and only use your remote to control power, volume, etc.
If you take the back off your TV and locate where the side panel buttons are, you should be able to see a wire connecting the panel to the button control board. Try disconnecting this wire.
Let me know if disconnecting the panel fixes the volume fluctuation issue. If it does, you may want to consider looking for a replacement. At that point I can try and help you find the part online!
Good Luck!
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Carolyn Brandt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 1,987
