メインコンテンツにスキップ
New Contol board, new problem!
Our Frigidaire electric dryer (model GLEQ2152EE1) started randomly beeping. Error code diagnosis said we needed a new control board. New board installed and the beeping stopped, however, now the numbers for timed drying are nowhere near what shows on the digital display. i.e., when when you turn the dial to 75 min., 30 shows up on the digital display. I reported it to the place where I bought the part and they sent me another control board. Installed it today and the same problem. Is it possible we got TWO defective control boards or is it something else now?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
@hermine exactly which error code did you get?
さんによる
E93 was the original error code
さんによる
コメントを追加
2件の回答
ベストアンサー
it probally means it might need a new lcd driver as well as i can tell.
your trusty tech source,
bacon
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
bacon, Thanks for the suggestion. Have ordered the part and will let you know if that solves the problem.
さんによる
Actually, installing this part did not solve the problem. :(
さんによる
then you may need to do some programming for the display output.
bacon
さんによる
コメントを追加
The control is probably 180 degrees off. You will have to find a way to turn it with the knob out since it is keyed. I have had to do that before with my own dryer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Holly McPheeters さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 123
