メインコンテンツにスキップ
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530回答 すべてを表示
Help identify cable connection inside the computer
Trying to reassemble an iBookG4. There are two cables coming from the right-hand side of the LCD hinge. One has a silver, squarish end and copper-colored cylindrical connectors, which, I believe, connects to the Airport Card. Is that correct?
The other cable has 6 wires running into a straight, single line of sockets. I don't know what this cable does or, more to the point, where to connect it.
Can you help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
one of theese is an lcd cable, that would be your lcd cable, the gold end ones connect to your airport card
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
George Roland take a look at these guides. Each one of those will have the proper explanation with the Logicboard removal guide. Just pick your proper model.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
George Roland さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 40
