メインコンテンツにスキップ
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
56回答 すべてを表示
overdrive is not working the way it should
when I am driving between 40 and 50mph it works fine but when over 50mph when you give the car gas it keeps kicking out of overdrive until the computer goes into default mod then it works fine
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It might pay to get a code reader on it & let us know what it tells you. Sounds like the transmission control computer is giving problems. Open it up & have a look for the obvious capacitor leakage problem with this one. These computers have a history of SMD chip resistors going open circuit, which is impossible to spot, but easy to measure with a multimeter. I've personally repaired hundreds of similar systems over the years.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Dale Plantz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 98
