Hard Drive Replacement Guide
Hi,
how can I replace the Hard Drive,
is this the same way as for the PB 1-1.5 GHz
Thanks for any help,
Lutz
この質問は役に立ちましたか?
Hi,
Lutz
この質問は役に立ちましたか?
if you use the guide for your powerbook g4 aluminum 12" 867mhz to remove the logic board, follow steps 1-25 and it will show you how to remove the hard drive. then just follow the steps backwards to install the new hard drive.
here is the link to the correct guide for your computer,
このアンサーは役に立ちましたか?
+ good
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 713
