Ld showed up on the timer
This showed up on our washer and is not drawing nor is water coming in nor is it spinning, what has happened?
foxpj it will help if you can get us the complete model number for further help. Usually the Ld Error is caused by the washer taking too long to drain water from the washtub
(Stored Error Code F32)
Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96″ to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Check on here to see how to run the diagnostics test. You'd be interested in runnig the pump test. This document should prove invaluable to your repair FrontBravos.indd
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 10
過去 30 日: 18
今までの合計 4,409
