メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
The phone is not charging even though it shows the lightning bolt.
I have an iPhone 5c here in my shop.
It indicates the phone is charging but does not seem to ACTUALLY be charging.
I tested out a new battery and it was the same problem.
Swapped out the piece that has the Lightning port, headphones, speaker etc and inserted a new one. Same issue.
I looked online on this issue and saw a lot of iPhone 5s issues regarding a burned fuse but the fuse is of course, not on the 5c mobo.
Has anyone else experienced this and if so, were you able to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Check the battery connector. Make sure its solid and not coming up from the board. Make sure there are no bent or missing pins. If that all looks good, Google the schematics for the 5S. Chances are that one of the charging components popped.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
checked them out, nothing is bent, all pins are there, and I tested it with a new battery and the original one, both in excellent condition. This is a 5c though, havent been able to find a schematic for that yet.
さんによる
コメントを追加
回答を追加する
shinseraph22 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 1,080
