メインコンテンツにスキップ
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60回答 すべてを表示
Why is my laptop making a loud noise around the fan area
Hello, so the problem is way before it got really serious. Before whenever it made a mad rattling shake and loud sound i just shut if off and when i turn it back again it's back to normal. But this time whenever i do the same procedure just a few minutes into using my laptop it makes this really scary sound and vibration here is a sample video. I don't think that it is on the hdd because the fan area has the most vibrating area and the loudest part of the noise. My laptop is just 1 year old. https://youtu.be/1dJ1Vnh9gpk
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Verify whether the laptop is still within the warranty period of 1 year.
If it is contact Asus customer support regarding a warranty repair. Even if it is just outside the warranty period by a week or so contact them anyway. A fan should last longer than 12 months.
You can prove whether it is the HDD or not by going into Control Panel Power Options go to the advanced options and set the HDD to turn off after a set period of time. When the HDD shuts down (to save power) if the noise is still there it will be the fan as it is the only other moving object.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
juancarlosvgalvez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,344
