My front cover glass broke
Can I replace the front cover?
My camera broke as well...
I pulled out the silver ring that surrounded the original broken glass (it is easy to remove using a small pliers), cleaned all the broken glass pieces and ordered a flat glass watch crystal diameter 29mm Thick 1mm on aliexpress
Once it arrives i believe I can glue all the parts together again, almost like the original camera.
(search for "flat glass watch crystal diameter 29mm thick 1mm" on aliexpress, costs less than 2 dollars)
このアンサーは役に立ちましたか?
Hi,
I'm curious to know if that worked and if the camera kept being waterproof. I thought about replacing the whole front cover but I don't find that part anywhere...
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 164
