メインコンテンツにスキップ
The Kodak ESP 3 is an all-in-one photo color inkjet printer.
35回答 すべてを表示
Why wont my printer go past print head loose or missing
how do i remove the print head on my Kodak ESP C310
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント:
I have tried to press hard on the bullseye fingernail little stamp but I cannot get the printhead out of its position. I have a Kodak ESP 3250 machine and its not letting the colour cartridge seat into the open box for it. I have tried with Kodak to get the instructions but they are just saying I have the wrong cartridge but its a Kodak 10C. How do I remove the printhead as Ive said I tried the pressing hard on the label with the fingernail on the target but nothing happened. HELP!
さんによる
If I could transport my Kodak ESP 3250 printer scanner to somewhere within a reasonable distance from Milton Keynes or Bedford I would do so to get the printhead exchanged because I think its the printhead that has had its day.
さんによる
Please reply to me message and give me details of approx cost of replacing the printhead if that is the reason for the printer not working.
さんによる
Is this the board on the back of the print head?
さんによる
コメントを追加
3件の回答
Printers use logic circuits, which are computer circuits that operate by recieving inputs and sending outputs. The logic circuit is picking up an input from the print head that it is interpreting that the print head is bad. The logic circuit that is directly connected to the printhead could also be causing the error code
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So what you need to do is replace the carrier mechanism/printhead, if the error remains replace the logic board that the printhead is directly connected to.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Bullseye is to be mashed when installing print head. There is a gray latch above bullseye you press to release print head.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ivanbmm169 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 2,859
