Change tv channels by it self
My TV 't change channels without using the remote on by itself it goes from the dish Network to the local channels and then the local channels will also change by itself how do I fix
I had an intermetent issue with my tv i tried allsort's but then found the AV board inside the tv had some componant's that had corrosion / corroded. After cleaning with isopropyl alcohol and a toothbrush I then resoldered the culprits with new solder. It has now been running for ages without an issue. You could also google the tv's model number , ie Phillips 32---------led tv dvd combo channel randomly changing issues or channel switches over by its self. If you do not find anything in relation to your problem try writing it another way but keeping the make and model number.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 14
過去 30 日: 61
今までの合計 2,271
@robrack what model is your TV? You removed the remote far enough to rule it out as the cause for this?
oldturkey03 さんによる
Gary さんによる
