Why is my riding lawn mower burning oil?
What causes a riding lawn mower to burn oil?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Jud, check to ensure the crank case is not overfilled with oil, carburetor float/ fuel shut off solenoid may have stuck allowing gas into engine overfilling engine oil, if this is the case fix carb. and change oil/drain thoroughly and fill using fresh proper grade oil, before starting again. There are a lot more reasons for engine to smoke this is one of the common ones along with blown head gasket.
See links below for other causes and fixes.
https://www.briggsandstratton.com/na/en_...
このアンサーは役に立ちましたか?
Hi, L Pfaff. Thank you very much for your informative answer. I tried to post this comment a few minutes ago, but I don't think it posted. I wanted to be sure you knew I am most grateful! Judane
Judane, your thanks is appreciated, as with out it we are never sure if we were of assistance and it is always good to know we have helped some one. Have a good day.
Any engine will burn oil if you have worn piston rings, as the oil will pass through the narrow gap between the piston and the cylinder wall and burn in ignition chamber. You can also burn oil from worn exhaust valve seats. And finally, if you're using too lightweight of an oil, the engine can burn it as well.
このアンサーは役に立ちましたか?
Thank you so very much! Nice yellow car you got there!
Thank you very much!
Jud, Most common reason for small engine to all of a sudden to start burning oil is an over filled crank case. Some times a faulty needle and seat or fuel shut off solenoid can stick open, allowing gas to flood into the crank case overfilling it, thinning oil and allowing it to burn very easily. For more trouble shooting and to learn possible reasons for small engine burning oil/smoking check the attached links, good info to be found there. Good luck.
このアンサーは役に立ちましたか?
A blown headgasket causes sudden oil consumption and power loss.
As mentioned an engine filling with fuel due to needle valve sticking is very common and it can really damage an engine fast too. Damage to rings ,rods, valves, heads/gaskets instantly. Creates excessive wear to cylinder/bearings etc as oil is too thin if ran long.
Lot of damage can occur by this and the main reason all small engine manuals state operator should check oil before each use.
Not only checking for low oil it's for too much oil in the crank case from this occurring at any given time.
Ethanol makes needle valves swell & stick in older engines.
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 34
過去 30 日: 147
今までの合計 46,673
