メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
non responsive screen - screen is not cracked
I have an iphone 5s with a BLACK and unresponsive screen. Nothing shows on it and it does not respond to touch. This phone screen is 100% not cracked but loose in the metal case (yes it's been dropped a million times - screen protected by screen saver - and lives in a back pocket of teen's tight jeans)
I can use quicktime to see/mirror the screen and the phone is charging and powered on.
Is it just the screen?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
No you can't use QuickTime to mirror screen.
You should check if the computer responds to the phone at all.
Could be something else instead if the screen.
When you have a tempered glass screen protector the screen can crack easily if the frame dents inwards and pushes into the glass on drop.
さんによる
Quicktime can mirror the screen no issues at all . it allows me to see that the phone is responding to charging etc.
さんによる
Wait what? I never knew you could use quicktime to mirror the screen. Going to try that next time I get a client's iPhone with backlight busted.
さんによる
コメントを追加
2件の回答
ベストアンサー
Ben is right, this could be a simple case of a faulty screen. However, the best way to determine this is to plug it into a computer (when you know it's on) and see if iTunes recognizes it is plugged in. If it does you know at least certain components on the motherboard are functional. A replacement screen could (and likely will) do the trick. However, it could also be an issue with the chips on the board themselves. That's a more complicated repair...so let's assume a faulty screen. Return the one you got, get a new one, and check for persistent issues.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
yes i tunes can see the phone - unfortunately the user does not have touch unlock enabled so it can't be backed up as the screen is not responsive to touch.
さんによる
Well that's good news! You can replace the screen and then you'll be able to restore full functionality. Customer should be very happy.
さんによる
コメントを追加
I'd say, see if any local phone shops might check it out for little to no cost...
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
La Qu さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 202
