No steam coming out
No steam coming from Morphy Richards iron
Have you put water in it? Have you pushed the button for steam. When you have done this, put the so it is vertical and sitting on it's little base. Now allow it to warm up for a min it or so. Then try it. I hope it works for you.
このアンサーは役に立ちましたか?
Yes I've put water in and left it now to cool of to try again
No tried all that no joy
If you’re steam irons stopped steaming try this simple trick on the water filler cap there is a small hole if it gets blocked the steam stops unblock it and wall-a steam again
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 15
過去 30 日: 51
今までの合計 5,300
2 件のコメント
I have descaled it about 5 times but steam light staying and no steam coming out
toffeenose さんによる
Hi descaled morphy Richards steamelite iron about 5 times but steam light stays flashing and no steam coming out
toffeenose さんによる
