メインコンテンツにスキップ
Doogee Valencia2 Y100 Pro released on 5th July 2015.
5回答 すべてを表示
My storage seems corrupt, cant access photos/documents, gallery empty
My gallery says it is empty and any photos I take are not saved there. I can still see photos in Whatsapp messages so I think something is corrupt. Ihave not deleted the photos. If I try to connect my phone to a computer I get the message "Unfortunately the process android.process.media has stopped". I have tried all the recommended fixes for this. So I can't use a computer to view my files. I don't have an external sd card. I have tried Norton antivirus and it's not picking anything up
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hi, i had the same problem and it was solved when i removed the guest user , as written in the following link
http://www.nairaland.com/2532812/infinix...
(those having problems with internal memory, sd card, camera and other apps delete guest mode and reboot ur phone. and dont use it again)
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi,
how do you manage to remove guest user?
さんによる
try to change to guest back to admin and then remove it
さんによる
Hi,
thanks, I manage it. Now gallery is returned back. Everything seems fine.
さんによる
コメントを追加
Hi Kim,
did you find any solution? I'm having the same issue.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi, not really. I put in an sd card which all my new photos now go to but I can now see my old photos on the phone also (I have 2 "camera" locations) but I can't see the old ones if I connect to a computer so I cant get them off of the phone.
さんによる
コメントを追加
回答を追加する
Kim Shoard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 642
